Tavel Trailer springs and shackles
tewitt1949
I have a question about the springs and shackles on my travel trailer.  My trailer is a 32 foot and weighs about 8500.  Back when it was new they used brass./bronze for bushings.   All moving points on the springs have grease zerks  and are greased regularly/yearly.  I have greased them but they are a pain to get them to take grease sometimes.  I've replaced them with bronze bushings  which is the same that came from the factory.  Its  been a few years since I replaced them and I'm thinking it probably needs rebuilding again.  My question is instead of bronze/brass bushing, what are your thoughts on something different that bronze/brass.   A few years ago I bought some black stuff that appears to be nylon but I they had a different name for it.  It appeared to be a little harder than nylon.
     New bushings have graphite buttons made right in the bronze that don't need greasing.  I have a friend that works at a rv trailer dealership and he says the new bronze/graphite bushings aren't what they are cracked up to be.   Ok, what's you thoughts on nylon type stuff for bushings.  I am a mechanic/machinist with all the equipment  (lathes)to make the new bushings..
Terry Witt
6 REPLIES 6
RAS43
I never had good luck with nylon/plastic bushings in any trailer I have owned. My present 5th wheel has  the original brass bushings and is 19 years old. I jack up each side by the frame to lube each zerk every spring. This way the zerks easily take grease. We normally travel 3-5000 miles a year. If we travel more then that I will lube it a second time.
amxpress
 I guess I'm old school. If you have bronze/brass bushings that can be lubricated, I would stay with them. I've had 2 trailers with the white nylon/plastic bushings that wore out and were replaced with the bronze bushings with the zerk fitting bolt. Messy, but they last a long time and do the job.
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
QCMan
Nomad III
Nomad III
Just under 10 thousand on the set and still tight. Replaced the original plastic bushings that were no longer complete circles after about 2600 miles. Also replaced the solid equalizer with one that has rubber in it to take the shock out of bumps. I grease all the fittings about every three thousand.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
opnspaces
Navigator II
Navigator II
How many miles do you put on these bushings? I think most of us are still running on the plastic bushings without any real problems. Since you already once replaced the bronze bushings I wouldn't give a second thought.
QCMan
Nomad III
Nomad III
If it is certain ones that always give you a hard time those bolts may have been installed with the internal grease holes slightly off horizontal. The fix is to reorient the bolts which can also be a pain job.
Krusty
Unless you are putting a lot of miles on the trailer, most of that stuff should last almost a life time. I think the brass or bonze greaseable bushings would be the best way to go. Jack up a wheel at a time and give everything a good shake and check for any excessive wear every year or so. Make sure to grease it regularly and if any bushings dont take grease, try again with the weight off that joint or clean or replace the grease fitting
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
