Sep-27-2013 05:11 PM
Sep-30-2013 05:27 PM
Hiking Hunter wrote:RCMAN46 wrote:
Do you mean your speed is varying!
No, the speed is as solid as a rock. What I meant was the throttle slightly increased/decreased to keep the truck as the same speed. But again, this may not be a true problem - it's pretty suttle. Heck, it may have been due to a gusty head wind the first time I noticed it. It's something that I'm going to keep an eye on as I drive the truck. I just don't get it on a flat and level roadway for long enough to evaluate it very often.
And the only reason I mentioned the 3.42 knuckle was because that's where the discussion for this thread had turned, and my earlier posts that the 3.42 seemed fine for me and my towing requirements, and was NOT the cause of any "hunting".
Sep-30-2013 02:15 PM
Hiking Hunter wrote:I think you are being way to sensitive to what your truck is doing going down the road. I don't pay that close of attention to mine. I set the cruise and remove foot from accelerator and let it do its thing.RCMAN46 wrote:
Sep-30-2013 01:04 PM
Sep-30-2013 11:26 AM
Hiking Hunter wrote:Hiking Hunter wrote:
I do notice, though, some "hunting" when using cruise control unloaded on flat and level ground.
I need to elaborate a little on my statement. When I said "hunting" I was referring to the cruise control hunting for the right speed with the accelerator; and then only when on flat and level ground. There is no transmission hunting. I have the 3.42 back end.
Sep-30-2013 06:40 AM
Sep-29-2013 08:34 PM
ib516 wrote:
I think if you get a SRW, 3.42s are your only choice with the diesel. You need to go to a DRW to get 3.73 or 4.10. Much like Ford. 3.31 or 3.55 in SRW trucks.
Sep-29-2013 07:31 PM
Sep-29-2013 01:00 PM
Vulcaneer wrote:I think part of the hunting problem some talk about is because the torque curve now is not as flat as my 5.9. The curve I saw shows it peaking then falling off some as rpm goes up was not impressed with that part. But them 250 more ft.# than mine is a lot so maybe it evens out by 2600-2800 range.
I just bring this up because my truck runs 1600 RPM at 65 mph in top OD gear. Has 20" wheels/3.55 RAR. And .67 sixth gear OD. According to the torque specs it's peak (850 ft lbs according to the window sticker) is at 1600 RPM. I don't find it hunting gears when towing heavy on minor grades. In my mind I think this is pretty good gearing for heavy towing. Makes cruise control very useable when towing.
If the Ram really does run Rpm @ 72 mph was ~1500, I would like to see a lower RAR gear choice. The Aisin trans is a great unit. The Cummins runs all kinds of torque. But I wonder if the gearing makes best use of the engine trans combination in real world towing situations. I just don't like to hear any tranny hunt. And if using Cruise control, it needs to run at peak torque to be really effective when heavy towing.
Certainly not badmouthing the new Ram. Sound like a really fine truck. I just have this one question is all.
Sep-29-2013 12:33 PM
Sep-29-2013 10:09 AM
Sep-29-2013 08:26 AM
It was a 3500 SRW 4x4, laramie, crew cab, and it was equipped with 3.42 rear axle, the 850tq Cummins, and the Aisin 6 speed auto.My truck exactly, in a long bed.
raygreg wrote:I've had mine about 5 weeks now, with two camping trips chaulked up. It tows like a dream. I can feel a big difference because it is a heavier truck than the F250 I have been towing with - more "solid". I think you will find it rides better towing than when it is unloaded. I reduced my tire pressure down to 70 in the rear tires, proportionate to my payload. I do notice, though, some "hunting" when using cruise control unloaded on flat and level ground. Not sure about that though, there's not much of that around here. I love the exhaust brake, and the way the tow/haul mode interacts with it. The EVIC is great, the only thing RAM left out which I wish it had is EGT; all other parameters are there.
I bought one about a month ago, just got a B & w Turnoverball and Companion hitch put in, getting ready to see how it tows.
Sep-29-2013 07:53 AM
Sep-28-2013 03:12 PM
Rpm @ 72 mph was ~1500.
I guess I would question the gearing. Seems pretty high? Assuming it develops peak torque at 1600 RPM, at 65 MPH (highway speeds) it would be below peak torque. Not a problem for non towing. But if towing medium/heavy (say 14,000 LBS), do you think it would be shifting a lot when encountering slight grades at 65MPH?
I would think a bit lower gear might be better for heavey towing.
Sep-28-2013 01:12 PM
