- mgannExplorer
- trailer_newbeExplorer IIIThe temporary out of service has been going on for a while. I have to load pages 2 or 3 times, then it actually loads.
- mgannExplorerok, last try and then I'm over it. The pic I resized is 298w x78h and 27.9kb but it still gives an error saying I exceed the 500 and 100. So last try and thanks for the help.
- 2012ColemanExplorer II
mgann wrote:
I see the changes in your profile picture - but your not in the correct place for a signature picture. When you are editing your profile, look at the top for this:
test
To change settings such as your signature and privacy preferences, go to your Preferences page.
Preferences Page is a link. At the top is where you edit your signature. You can put text or a picture there.
Put it in the same place where you have this info:
2014 Chevrolet 1500, crew cab, srw, 2wd, 4.6 gas, Stock class V, 1995 Mallard by Fleetwood model 19n
Right there it says Signature picture - and there is a Browse button to select the picture. - mgannExplorertest
- mgannExplorertest
- mgannExplorerUsing a wesite www.picresize.com, I have tried once again, so we'll see. I've also noticed I keep getting " temporarily out of service" and that could be part of it.
- mgannExplorerI thought I did what you said to do and I changed the pixels but the kb still exceeds the 30kb and that is what I don't know how to change. I thought I tried to put it where it would show up with my sig but even that's not showing now. I appreciate your help but it's not enough for me to worry about. Thanks
mgann wrote:
I get that, but did you do what I told you to do? Right click it, select properties, then look at what it says by size on disk. If its over 30, it doesn't matter what you set the pixels to in paint.
I did resize the pixels using paint but when I try to upload the pic ,I still get an error saying it's exceeds 30 kb and that is where I'm stuck, but thank you.
I clicked your profile - see the pic there - are you putting it in the right place? Nice camper btw - trailer_newbeExplorer III
mgann wrote:
This is my last test and try. If it's not there, then so be it.
Same for me too. This site seems to be using some clunky HTML code and I could never get it to work. Jayco forum, no problem. It is what it is...
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 26, 2025
