- seaeagle2ExplorerMost digital tstats have a set up menu to change cycles per hour and select f or c
- brulazExplorer
SoundGuy wrote:
brulaz wrote:
So people are installing these simple digital thermostats for the :
- Digital indoor temperature readout?
- Backlit display?
But you have to add a separate switch to control A/C fan speeds.
Is it worth it?
No question about it. Temperature control is much tighter than with any stock bi-metal thermo.
So the furnace must turn off and on more frequently to maintain a more constant temperature?
One other advantage for some of us Canadians would be to get a Centigrade scale I suppose.
Don't think a remote is in our future. There are too many of them floating around the trailer already.;) - 2oldmanExplorer II
brulaz wrote:
With a remote it is.
Is it worth it? - SoundGuyExplorer
- Backlit display?
Is it worth it?
No question about it. Temperature control is much tighter than with any stock bi-metal thermo. - brulazExplorerSo people are installing these simple digital thermostats for the :
- Backlit display?
Is it worth it? - Dakota98Explorer
- samhain7ExplorerThanks SoundGuy. Exactly what I was looking for...
- SoundGuyExplorer
samhain7 wrote:
The one I provided a link to does have two AA batteries...
The issue I have is that they do not sell the HUNTER brand in Canada. So I am (and probably others in Canada) looking for GOOD alternatives..
I have seen about two comments in this forum that Honeywell is not recommended..
That "24 volt" reference is to typical home heating situations which are commonly 24 volt ac and has absolutely nothing to do with your trailer's 12 volt dc system. Good grief! :S
Since you're here in Canada as I am where many products common to US consumers aren't available the solution is simple ... just head to your local Home Depot and spend $50 on this Honeywell Non-Programmable Thermostat that will work perfectly for controlling the furnace and/or air conditioner in your camper and which is particularly easy to use as it features a backlit display that lights up whenever you push the temp control buttons. - 2oldmanExplorer IIYou don't have to buy a Hunter. Any battery operated digital, including that one, is fine. The other posters aren't reading carefully.
I have a Lux w/remote and it's real nice. - samhain7ExplorerHey downtheroad .
We don't even have the one you listed in Canada.
Lots of Honeywells...but not that one..
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
