aarond76's avatar
aarond76
Tightening Stair Bolts
On my trailer the bolts that hold the stairs tight to the floor of the camper need to be tightened. The nuts are rusted to the bolts and I have not been able to get anything to hold tight enough to the threaded end of the bolt to get the nut to break free even after soaking them in PB Blaster. You cannot get to the head of the bolt is it is inside the wall of the camper. How is everyone else tightening these? Thanks.
  • I had this happen. I used a nut spliter to get the old nuts off and chased the threads then replaced the nuts.
  • The bolts that hold the steps to the floor have a round flat head with a square shoulder under the head, similar to a carriage bolt but with a flat head, then the floor covering is put down over them. They are driven into the hole so you can tighten them from the underside. I found new ones at a hardware store, but it's been a few tears ago.
    As far a PB plaster goes, it's not worth the price of the little straw that comes with it. Go to Kano labs and order a can of AreoKroil, and a can of Silikroil. You'll never use PB blaster again, this stuff works!
  • PB Blaster or Liquid Wrench is what I always use to free up rusty bolts. I generally soak them several time over a period of a week before trying to break them loose. Bad thing is you may have to go in and replace the entire bolt. Since you don't have access to the other end.. Are you sure it is not one of these screwed into a floor joist.
    Check the link.
    Double end hanger bolts
