Timbrens, air bags or air hitch
12th_Man_Fan
Probably opening a can of worms here, hope you have some popcorn handy.
I have a GMC dually and pull a 5th wheel with a pin weight of approx. 4,000 pounds.
The 5er has a trail air pin box and when I am on a decent road you hardly know the rv is back there but when I hit a typical Texas bridge transition there is a pretty harsh reaction and I am trying to reduce that as much as possible.
I know the air hitch is probably best but I just want some feedback from those that have had experience with all the above.
Thanks in advance.
Doug
PS forgot to mention I have the Bilstine 4600 shocks.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
24 REPLIES 24
IdaD
wilber1 wrote:
With Timbrens I didn't notice much difference in ride when loaded. I had them on the truck for several years. Guess it just depends on individual circumstances.
I really only notice a difference when I hit a bump at highway speeds. They don't allow the truck to dip as much in the back so it settles down the ride. Just cruising down the road feels about the same to me as it did without them. Maybe slightly stiffer feeling but certainly not dramatic.
Unloaded, no difference. I like them.
2015 Cummins Ram 4wd CC/SB
Cummins12V98
I ran 5psi unloaded in my PacBrake bags, the ride difference solo was NOT noticeable. Loaded they smoothed out the bumps!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
n0arp
Dayle1 wrote:
6.7 tow rig wrote:
So you are happy with the way the bags feel loaded then? That was my concern. What about unloaded?
Unloaded, with minimum psi (15 psi I think) you won't know they are on the truck.
Absolutely not true. I ran my Air Lift 5000 Ultimates at 5psi most of the time, and definitely knew they were there.
2000 Country Coach Magna 40',
4380W solar, 22.8kWh LiFePO4@48V, 450AH AGM@12V
2020 Jeep Wrangler Unlimited Rubicon 2.0T, cloaked on 37x13.5s
wilber1
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
GeoBoy
tinner12002 wrote:
X2 on the timbrens being junk. They make the truck ride like its bottomed out when loaded...very harsh ride!! Yes they were adjusted correctly. Went with air bags and haven't looked back!
I don't believe Timbrens are junk, they just didn't work for your application.
C_Schomer
I have airbags with a homemade expansion tank, air adjust Rancho shocks and in-cab control for both. I could feel the bags unloaded, slightly, so I added the exp. tank and that made them absolutely undetectable. The adjustable shocks make every bit as much improvement as the bags... They compliment each other very well. I adjust the bags for the load and the road condition and with the shocks I have full control of the sharpness and oscillation. I also cut the ends off the bottom overloads which was the first thing I did. I spent a LOT of time on my suspension but I don't know if my recipe will work for every truck. I made one change at a time til I got mine perfect. You might need to experiment a little cuz every truck and load is different. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
Dayle1
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
cummins2014
Never felt a difference with or without airbags unloaded, but a much improved ride loaded. Have had two different trucks, and both were the same with airbags as far as ride.
6_7_tow_rig
2018 Dodge Ram 2500 Laramie Cummins 4x4
2013 Primetime Lacrosse 318bhs
tinner12002
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
6_7_tow_rig
I tried Timbrens and unloaded there is no difference because they aren't in contact with anything. Loaded, the ride was atrocious. Every single bump whether it was big or small was jarring. It was so bad that on the way to Myrtle Beach, which was the first trip using them, I removed them in a gas station parking lot because I couldn't take it. Don't waste your money. I want to try airbags but am worried the ride will be like the timbrens.
wilber1
I had Timbrens on my previous truck. No difference in unloaded ride as they aren't contacting the axles. Loaded they helped with leveling and stability but didn't do anything to improve the ride.
2011 RAM 3500 SRW
n0arp
JTrac wrote:
I've had all 3. Had the Timbrens on a 2012 GMC 3500 srw and the ride with a Demco Glide Ride pin box was pretty bad, especially the chucking. Changed them out for some Air Lift air bags which helped greatly, even the empty ride. When we got the dually I transferred the bags to the new truck and ordered a Trailer Saver BD3 air ride hitch. For the most part I feel no movement from the fifth wheel. The really bad stuff I can feel but not near what it was before the BD3.
deltabravo wrote:
Torklift Stableloads.
I had Stableloads and air bags (Air Lift 5000 Ultimate) both on my 2500HD. Air bags made the unloaded ride notably worse. Stableloads made it unbearable. Fortunately for most (not me, because my toolbox and hitch put too much weight on them to disengage), you can disengage the StableLoads when not in use. Air bags INCREASED body roll when towing. StableLoads fixed that. Probably not an issue with a dually, but there you have it.
BD3 is amazing. I'll never go back to a fixed hitch. If you want the ultimate ride, go with a Kelderman and a BD3. Otherwise get the BD3 unless your factory suspension is unable to support the load.
Strabo
No bags, stock F350 with overload spring, new shocks..Cooper STT Pro tires. Works fine.
Heavy truck tho.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
