Oct-12-2016 09:33 PM
Oct-19-2016 05:14 PM
Oct-19-2016 01:03 PM
blt2ski wrote:
I have tpms on my sprinter van for work.......I've had a blow out!
As I noted earlier, I'll take a single super wide over duals any day of the week. Only advantage to duals as drivers brain! Otherwise, traction, braking, mpg's etc, is better with a single!
Marty
Oct-18-2016 09:48 PM
Oct-18-2016 08:17 PM
Groover wrote:lawnspecialties wrote:
I don't get it. Since I don't even have an "inside tire", I don't have to worry about the "inside tire" blowing out. So in theory, having a dually just increases your chances of having a blowout by 50%.
:B
Probably increases the chances by lot more than that since it is much harder to spot a low or flat tire if another one is carrying its weight. I had both inside tires go flat once and the only way I noticed was that I only left one tire track on some soft dirt. Also, the only reason that it went flat was the extenders to make the inside wheels easier to fill let all of the air out. Fortunatly, I had not driven far or fast so all I had to do was get the tires inflated, remove the valve stem extenders and put on a TPMS.
Oct-18-2016 10:16 AM
:B
Oct-18-2016 02:51 AM
blofgren wrote:transamz9 wrote:blofgren wrote:
Another thing to consider is the fact that a heavier fiver WILL put a SRW truck over it's GVWR. Here in BC, DOT has been known to do roadside weight checks of RV's and they do enforce the GVWR of the truck. If you are over the GVWR of the truck, you drop the trailer on the side of the road, likely get a ticket, and can pick up your trailer from the towing compound with a truck that's rated for the load. I am well under the ratings of my truck and have nothing to worry about in this regard.
At the end of the day to each his own. I have owned both; my last two trucks have been duallies and I will own one as long as I have a heavy fiver. I noticed a considerable difference when I upgraded to one.
You got that right....to each his own.
But why on earth would a dually have higher GVWR and GAWR's than a SRW if there was no difference or benefit????? :h :B
Oct-17-2016 10:31 PM
RCMAN46 wrote:Perrysburg Dodgeboy wrote:
LMAO so this morning I go out to the truck to go home from work and low a behold what do I find on the dash after starting it.
Yep this
This comes up along with a chime that goes off about every thrity seconds for about ten minutes :M
What was the pressures on your outer duals?
Oct-17-2016 07:52 PM
Oct-17-2016 07:49 PM
Cummins12V98 wrote:
I can say from traveling South Saturday and Sunday thru WA and OR with high winds and rain I never felt unstable. Did I feel the wind sure I did. Would I tow a 14-16K 5er with a SRW in those winds NO WAY!
My combined is over 33K.
Dually's are not NEEDED for everyone but it's those extreme situations that make having a Dually well worth it.
Oct-17-2016 07:42 PM
Oct-17-2016 06:20 PM
Oct-17-2016 05:55 PM
Oct-17-2016 05:45 PM
Oct-17-2016 04:43 PM
