kennyd63's avatar
kennyd63
Tire Pressure for TV
Just bought 4 new tires for my T.V.( P275 65R 18) that what it used to be. Now I have the same size, but they are (E load )Brand name is General Grabber AT2. It shows max PSI 80 LBS. At what PSI you guys keep yours while towing /and NOT towing?
Thank you in advance
  • That tire might an LT not a "P" if it's a 3400# rated tire.
    I run my LT's "E" ply at 80 rear and 65 front while towing . Empty, 60/60 works well on my 2500HD. I also run Bilstein shocks and that really makes a difference over OEM shocks, running loaded or empty.
  • I go with what's on my door placard from GM. 50 front, 71 rear. All the time. Tires seem to wear evenly, and the ride is good both towing and not towing.
  • Ideally you find the Load Inflation Table for that tire from General or find it on the net. Then you know exactly what General says is safe for what weight at what PSI. I have used them before for other brands never ran a General so cant point you to it.
    The vehicle placard is set to the psi for the OEM tire that corresponds to the vehicles max weight rating as they (the government) knows in general that most drivers are not good about checking tire pressures much less getting weighed and adjusting their pressures appropriately (if you look up the OEM TPMS specs/rules/laws for vehicles it pretty much comes right out and says that). If you weigh your vehicle and you get your actual weight or weights ie normal weight, loaded weight you have your upper and lower limit. My truck fronts are at 65 and rears 55 (I could actually run lower on the rears) unloaded, loaded I run 70 front and 65 rear based on my weights
    Here is an example of what I am talking about again it is not the correct one for your brand/tire but is just an example but General should have one
    https://toyotires-1524598101.netdna-ssl.com/media/2125/application_of_load_inflation_tables_20170203.pdf
  • When I had an F150 and was towing, I'd run the max psi on the rear and the door placard psi on the front.
  • I run 80 PSI in the fronts and 65 in the 4 rear tires on my DRW truck. I run 80 PSI in all tires on my SRW truck.
