rbpru wrote:
That's strange, I have not heard of a D range tire at 50 psi.
My ST 205's are rated C at 55 psi and D at 65 psi. I would definitely check with the tire maker.
Steel valves are used with 85 psi. tires so the 65 psi is a piece of cake. I still have the plain rubber one for my D rated tires.
Our friend from Indiana is in fact correct that rubber snap in valve stems are rated for up to 65 psi. That is their upper limit though, so I go up to the next higher rated stems, call it, just for peace of mind.
Here is a description of the different stems we are dealing with:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=208ps, here is an interesting little back story on all this. Earlier this year, I bought another new horse trailer. The sticker on the trailer and the factory sales brochure stated the trailer comes with load range D ( 65 psi ) tires. Oddly enough, when I got the trailer home to the barn, I noticed the factory had installed load range E ( 80 psi ) tires on it. And yet, it had "65 psi rubber valve stems".
Go figure.
