Tire size/gearing for Ram DRW
FireGuard
I’m getting closer to pulling the trigger on a new (2018) Ram DRW Cummins 4x4 Aisin.
I want to go back to a TC in the 10’ range and flat tow my Jeep.
I’m comparing a Tradesman model with 3:42 gears and a Laramie with 4:10.
I think for my purpose of carrying a 5k lb camper and towing 5 k lbs, the 3:42 would be plenty and would be better running empty.
I would like to add bigger tires but I think as long as the diameter is similar it shouldn’t pose a problem.
The truck comes stock with 235/80/17 which is 32” tall and 7.4” wide.
If I went up to a 275/70/17 the height is only 32.17” tall but 8.8” wide and I think the biggest I would want to go with would be a 295/70/17 at 33.25” tall and 9.8 wide.
So from my understanding the 275 wouldn’t change the gearing and maybe add a little rolling resistance due to being wider. The other 2 being an inch taller would change the gearing but probably not make too much of a difference??
I would get new rims with the proper offset rather than using spacers.
The Laramie is the granite color which is my favorite but the Tradesman is silver and $9k less. I really don’t need all the bells and whistles but the Laramie is a sweet truck.
Let’s hear your thoughts, primarily on the 3:42 vs 4:10 issues.
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
11 REPLIES 11
Grit_dog
Navigator
Navigator
Either gear ratio will be just fine. Not sure what issues you'd expect from either. You could do what you're doing with a gas truck.
If you want the most "power" get the 4.1s. If you want slightly better mileage running empty and like to drive fast on the highway, get 3.42s.
I'd assume slightly better mileage but haven't compared directly.
Comeoutswingin
I run a 255/80R17 (~33x9.5) on my 08 with 3.73s. I tow pretty heavy without the camper, usually around the 26k combined and it does that without issue.
With the camper, I find that if I lock out 6th gear I gain about 3mpg and my truck doesn't lug along. Would I run 4.10s if I had them? Absolutely.
2008 Dodge DRW 6.7, 255/80R17, StableLoads
2013 Host Cascade Dbl Slide
TxGearhead
I had a 2016 Ram 3500 SRW crew cab long bed 4x4 Cummins Aisin with 3.42, only ratio available. The only issue I had was that I would lock out high gear in hilly country pulling the 5th wheel. I replaced that with a 2018 DRW equiped the same except for 3.73 rear gears. I can't tell much difference. I don't think I would get 4.10.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
work2much
Love our Laramie. We have a ~6000 pound camper and flat tow a Wrangler Unlimited. No issues with power in the hills. Stock aluminum wheels and tires size.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
Kayteg1
I order my 2017 F350 dually specifically with 3.55 gearing as that was the lowest number Ford would build.
Still would not mind overdrive gear as with this gearing the trucks pulls up to 10,000 lb cargo on all grades between San Francisco and Las Vegas without dropping from 6th gear.
And the route has some nasty grades.
twodownzero
Considering the .64 overdrive, I really think that 4.10 is probably a better choice. My truck is a 2005. Only 3.73 was offered with the .79:1 OD mine has. In other words, mine screams going down the road compared to yours. Even so, I have to downshift on the really steep stuff. With a .64:1 overdrive, even the 4.10s will purr going down the road and it'll pull harder in every gear.
Putting wide tires on a dually, especially in the rear, is challenging. You can only space them out so far before you bust the max legal width. If I had a dually, I'd probably stick to tires in the rear that are near the stock width and only go wider on the front if I thought that was necessary for whatever reason.
I generally like lower gears. In my 05, I wouldn't have gone lower than 3.73 if offered, but if I had another overdrive, I would be thrilled to have the increased pulling power the 4.10s would give. Unfortunately my prayers for a 7 or 8 speed manual in a pickup have not been answered.
towpro
I had a 2015 Tradesman aisin with 4:10 and now a 2018 Larame with 3:73.
both with aisin only difference was the 2018 is 2wd.
The 3:73 does run around 500 RPM slower. TO be honest the 3:73 might help 1-2 mpg at highway speeds as we are moving a lot of air with the camper on. But even towing 7/14 box trailer without camper, I did not see that much MPG improvement over the 4:10. Now the 3:42 might be a little low for running highways with even just camper loaded, but worse case you might need to lockout 6th gear if the truck keeps shifting on hilly ground at highway speeds.
I think the 4:10 will have the advantage in the engine braking dept as I recall it would work all the way down to around 25mph.
But you said adding bigger tires: remember you need to get those tires between the truck camper jacks to load it (I live in central FL where I see these ridicules pickups with tires sticking 6" out past the fender edges).
I would picture bigger means taller tires, go with the 4:10. taller tires affect the gear ratio and the 3:42 may be too low.
But between the tradesman and Laramie, I would go with Laramie. I have the bucket seat option and I love those electric adjustable, cooled leather seats 🙂 The other options are also great.
I think they will both hold trade value, but Laramie will have better trade value (but it cost more up front)
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
FireGuard
Kohldad, Did you try running in 5th gear, 5th in the 3:42 is the same as 6th with the 4:10.
The tire diameter affects the ratio and I would get an aftermarket wheel with the appropriate offset to alleviate any issues with the tires being too close together to cause rubbing.
13Jeep Wrangler
07 Ragen 21FB
14 Suzuki DR 650
rhagfo
Diameter is NOT your issue, it is width with a DRW, you don't want the two tires too close to each other as you will be getting greater heat build up between the tires, and stuff getting caught between them.
dwrat
If you're not towing big heavy numbers then pass on the 4.10 gears.
Fuel mileage alone would make a big difference over time.
kohldad
My father has a 2015 6.7 with the Aisin and 3.73 gears. He finds he has to run in the upper 60s when he is pulling his 16k FW. He also finds with just his 5k TC he has to run at least mid 60s so it isn't straining. He wishes he had gone with 4.10s to bump the RPM up a tad while reducing speed a tad.
I borrowed his truck and TC for a couple of days and put a few hundred miles to see how I liked a much larger rig since we are wanting to upgrade. I agree with him that the 4.10s would have been a better choice. I had choosen the 3.73 believing Tow/haul mode would lock out 6th gear. However, the 6th gear lock out seems to only be done with my 6.4 Hemi, not the diesel (at least not with the Aisin).
If you are going up in tire size, I would definitely go with the 4.10s.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
