monkey44
Feb 03, 2017Nomad II
Tire Sizing?
Any website that tells the largest size tire that will fit a vehicle without needing lift or body work in wheel wells? I've tried searching, but the only ones I find want all the dimensions of whee...
Bedlam wrote:
Sorry, forgot about tire sizing: A rough way to tell how much clearance you have available is to run one front wheel up on the curb and cut the wheel to the steering stop. The clearance you have remaining between the tire and the rest of the car will tell you how much larger you can go from the current size without modification.
