โOct-07-2017 02:26 PM
โOct-12-2017 05:12 PM
Thuren wrote:
0.00 to 0.05 TOTAL toe, and 3.8-4.2 degrees caster on Diesel trucks, and 4.2-4.8 degree's caster on Hemi trucks.
โOct-09-2017 07:42 AM
brulaz wrote:dpatt67 wrote:
I've always heard not to reverse tires, even if they aren't directional. Is it a valid option to try?
Hmmm, never heard that before.
Always thought you could mount either side on a non-directional tire.
Mine have white letters on the outside, and the same lettering but in black on the inside. Always just assumed that was so you could choose one or the other?
โOct-08-2017 05:22 PM
brulaz wrote:
Thanks for the great advice folks.
Both sides show the same wear pattern and depth as best I can measure.
Think I'll just get the tires reversed for now, and then get the alignment done next spring when I buy new tires. Will ask for before and after readings and ask them to look closely at the toe adjustments.
โOct-08-2017 04:43 PM
time2roll wrote:brulaz wrote:I would be into the dealer and make a warranty claim now. Let them do the alignment and install new tires for this assembly defect. Nothing to lose.
โOct-08-2017 11:18 AM
โOct-08-2017 10:39 AM
โOct-08-2017 10:08 AM
โOct-08-2017 08:31 AM
Grit dog wrote:
I've read, not experienced, that some newer Rams HDs are coming off the line toed in far too much.
It's an old trick to make a car that wanders or has loose steering feel tighter going down the road.....seriously.
The other thing is, if you drive a lot of curvy highways and roads, outsides will naturally wear a bit more and usually feather a little, especially on a solid axle truck.
โOct-08-2017 08:28 AM
โOct-08-2017 07:59 AM
โOct-08-2017 06:58 AM
โOct-08-2017 04:59 AM
time2roll wrote:
First I would measure the front frame height when connected and compare to unloaded. Probably a long shot.
โOct-08-2017 04:53 AM
โOct-08-2017 04:21 AM
