bowebow
Nov 02, 2015Explorer
tires
2005 enclosed car trailer 9,995# rating. Sat around a lot. Tire side walls split and failed. Popular tire with bad reputation.2012 Installed gy marathons load d. Over loaded trailer 450# per tire. 1400 mile trip. All went well. 62 max speed.
2005. Wild cat 30 rk 5 th wheel. Tires held up. Valve stems went bad. Alignment bad needed to be aligned.
2008 cameo 31 ks3 5th wheel. Load e towmax. Build 5 2007. All tires failed. 2 replacements failed build 2 2009. Weight per tire, pass 2850#, driver 3100#. Tires built after mid 2009 did not fail. Lowered pressure under 80# to 75.
2013 Winnebago Minnie 2201. Tires load c, 50# max, set at 45#, drove 8000 miles no problems.
Cameo and Winnebago needed and got a axle alignment. Grapewood, Wyoming mi.
2014 fr v cross load d tire.max ptessure 65 psi set at 60# . 8000 miles no problems.alignment good
64 mph max speed . all trailers
All trailers fully loaded.
