Torklift extention
av8rds
Looking to upgrade my extension for my Superhitch. Using TL's measuring guide I come up with 38.25"s That puts me square between their 36" and 42" extensions.
Thinking of going 36" as the WD hitch adds a little length. Both are rated at the same weight.
Just curious what others would pick 36" or 42"??
'06 X-cab Powerstroke Dually 4x4
'75 Ford Bronco Rockcrawler
'08 Land Cruiser Buggy
8 REPLIES 8
av8rds
Thanks for all the opinions. Looks like the consensus is 42! My CURRENT trailer has an 18" extended tongue and I wasnt really worried much about the 36" but you guys have pointed out I really need to think about the future too.
Boatycall
Keep jack-knifing into consideration. If you run the shorter extension, and have to make a hard turn / back up tight, will the 36" make your trailer contact your TC?
I run 42.
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
Crumm
As you said the hitch adds length so I would go with the 36". If you go with 42" it will be sticking out when you disconnect trailer. The 42" would be fine but in my opinion the extra 6" is not required. Best route would be to fab your own so you can have the exact length you need.
2015 F350 SuperDuty, SC, LB Torklift hitch and tie-downs, LT285/75R18 Toyo AT II 4080@80psi
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS
arto_wa
According to your own measurement and TL guide, 36 inch extension is too short!
99 F350 4x4 CC DRW 7.3L PSD, 97 Bigfoot 2500 10.6
(11,900#)
89 Duckworth 17' Pro 302
Bedlam
Moderator
Moderator
Agreed. If you are towing something taller, go with the longer extension. If it is a boat or flat bed trailer, you can use the shorter one.
noteven
We were in between on our setup as well and went with the longer option as well because of what Fred said ^.
Golden_HVAC
Probably the 42" because that will put the trailer a little farther from the camper. This might become very important in a tight turn, or say you are leaving a gas station, and the truck front axle is in the middle of the road, about 1' higher elevation than the rear axle, so the camper is leaning back. Now the trailer tires are still up on the curb, above the street water channel, and say 12" above the rear axle tires. This puts the front of the trailer at a downward slope, and closer to the camper. To close, and you have the trailer trying to get into the camper, and that can not be good.
I saw the trailer trying to get into a motorhome in San Diego a few years back. I think it managed to get just a little under the skin of the motorhome, but am SURE that it made contact with the motorhome rear wall. I was watching them come out of the gas station, heading straight into the street, like trying to make a left turn, but actually going to the right. I have no idea why they pointed the RV so straight out to the center of the roadway, but at the last second started to turn to the right. It was a 3 lane street (each way) and the curb gutter would have been about 8" lower than the center of the roadway, with the gas station where the trailer tires are would have been about 12 - 15" higher than the motorhome rear axle tires. Bamm! That's gotta hurt. . .
Good luck with your travels, and take it easy leaving a gas station, take it at an angle, not trying to make a left turn when leaving the station if the angle is steep. If only one rear tire was in the ditch section of the roadway at a time, then the trailer would not have hit the back of the RV.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Raften
'01 Dodge 3500 CTD, Lance 1121, Air Bags, Rancho 9000, All Wheels Under Power When Needed, A Few Engine Mods For Increased HP
Burning Grease, 800 ft/lbs. of torque from something you throw away.
