โMay-31-2013 06:37 PM
โJun-07-2013 08:35 AM
Indy317 wrote:
Just to clarify: TV vehicle is a 2010 F150 FX4 crew cab, 5.4L, 6 sp tranny with cooler, 3.73 rear axle, tow pkg, trailer brake control, sway control, and 7350 lb GVWR pkg. Trailer is 28 ft with a dry weight of approx 5400 lbs. Fully loaded I figure we'll be around 6500 lbs.
โJun-07-2013 08:32 AM
โJun-02-2013 08:08 AM
Indy317 wrote:
I'm a little concerned about pulling our travel trailer out west and being able to pull up steep grades. I have a 2010 F-150 5.4L and was considering making a couple of power improvements like a cold air intake system and a cat back exhaust system. Has anyone made these modifications? If so, do you think it was worth the investment?
Thanks in advance for your help.
โJun-02-2013 06:33 AM
โJun-02-2013 05:53 AM
โJun-02-2013 12:23 AM
โJun-01-2013 11:19 PM
โJun-01-2013 10:07 PM
โJun-01-2013 10:04 PM
โJun-01-2013 09:04 PM
โJun-01-2013 08:58 PM
LeBout wrote:
I don't know why everyone is saying the OP should consider changing his gear ratio. The Ford F-150 he's driving has a 3.73:1 gear ratio which is great for hauling uphill. His gear ratio provides more low-speed wheel torque, which makes it easier to get the TV moving when pulling a trailer. That ratio also improves acceleration up to about 60mph. (Passing performance and speeds above 60mph is a matter of horsepower, NOT axle ratio.)
โJun-01-2013 08:15 PM
โJun-01-2013 07:51 PM
โJun-01-2013 05:15 PM
โJun-01-2013 03:26 PM
