scrapnread's avatar
scrapnread
Tow Vehicle Question
We just bought a 2014 Forest River Salem 27Rkss last week and now my husband thinks we need a new tow vehicle. We are looking at a Ford F250 7.3L power stroke diesel. What is an estimate of how many miles on the motor are too many? And any other opinions that you want to share. Thank you for your time and advice.
  • I don't think you can find many used diesel trucks for a few thousand unless they are on the way to the salvage yard. The 7.3 made by International is a pretty sought after diesel among those offered in Ford's despite it's age. If you get into the newer diesels, you get into complicated emissions systems that cost more to fix and maintain (cost of urea aka DEF). I'd buy a maintained "high" milage used truck over a lower milage truck that didn't look like it was maintained.
  • I wouldn't pay much for any vehicle with over 100,000 miles on it. The engine "may" be OK, Maybe not. But for sure the trany, windows, seats, hubs, brakes, suspension, wiper motors, and body have had a workout.
    So IF you can get it cheap, and I mean really cheap, Say, A couple thousand. You might be OK, IF they want more than 10K. Let it sit.
  • How many miles the truck has is not as important as how it got them. Check the history of the truck.
    Also if it's a truck from the coast, have a real good look for rust and have someone check it over for general condition. Consider any repairs on a miles per dollar level. Last year I put $2500 into the tranny on my 08 2500HD - Way cheaper than a new truck.
    Stu
  • The 7.3L was a workhorse. Like everyone else said, the engine will be the least of your worries.
    Diesels get a reputation for lasting 200k+ miles. There is some truth to that. Remember though the rest of the truck has also covered 200k+ miles. Rust, worn out axles, suspension, interior... The list goes on and on.
    If the truck was driven in the South without the road salt we have here, and was well maintained, then 150K miles isn't too bad. We have 2 different Ford one ton Diesels at work with over 170k miles. They run very strong, but the rest of the vehicle starts to nickel and dime you after a while. They are not 7.3L's though, they are 6.0L's
    Id look for a truck with less than 120k miles if you're looking at higher mileage trucks. I personally would probably never buy anything over 40k miles, but I drive too much a year.
  • There are a lot of 7.3L diesels running strong with 300k-400k or more.
  • Widely considered to be Ford's best diesel, and, not knowing specific weights of your tt, should have no problems handling it. All that said, 2oldman is correct. The engine may be the least of your worries. Definitely worth checking out.
  • That must be a 2003 or earlier truck. Even at 150,000 miles, the engine may be fine, but it's the other stuff you may have to worry about. Like transmission, front end, differential, oil leaks. That stuff can get expensive.
