moose308 wrote:
I am towing a trailer with 1000 lbs. tongue weight using reese dual cam weight distribution hitch.I realize more weight goes to the front tires.Door placard says 60lbs. front and 80 rear max.Truck is 3500 chevy single rear wheel.I was going to use 65 front 70 rear?
To my idea, weight distibution hitch only equalizes R/L weight and not even totally, but dont equalize front/rear.
So the tongue weight of 1000 lbs gives more then 1000lbs extra on the rear axle , and lifts up the front axle, for bumper pul, but mayby your tonge is somewhat in front of the rear axle.
Your probable 80 psi "maximum pressure" sugest you have LT tires and this maximum you think is in fact the pressure needed for the maximum load, wich you are allowed to go over even, but probably dont need to go over. TRA allows for LT 10 psi wich is 12.5% of 80 psi , so what chevor does with his 10 to 15 is totally save.
In Europe even for LT more psi is going over the maxloadpressure.
Its all about the weight on the axles, or better seperate wheels, that determine the needed pressure.
If you have not weighed, you have to do with the gross axle weight ratings ( GAWR) front and back. Also you need maximum load and that pressure needed for it ( your 80 most likely).
So search for it and give it here , and I will put it in my motorhome- tire pressure calculator.
Also give where the tongue is placed on the car.
