alex800's avatar
alex800
Tow Vehicle Tires upgrade
I need to upgrade the tires on my TV (2011 Expedition EL) due to some recommendation from other knowledgeable folks. I’m towing 7500 lbs travel trailer and recommendations that I upgrade my tires to load range D or E tires. There are not a lot of options in my tire size (275/55/20). The only tire I was able to find that is load range D rated is BF Goodrich All-Terrain TA KO2 LT275/55R20/D which is about $237 per. The other tire I’m considering is Nitto Terra Grappler AT which is XL rated that is about $190.
I need some recommendation. Should I spend additional $200 for D rated tires or will XL would be a safe choice?
I currently have Pirelli Scorpion STR with less than 2000 mi on them.
