Apr-06-2017 01:38 PM
Apr-16-2017 08:46 PM
Apr-15-2017 10:38 PM
dodge guy wrote:boonie wrote:
Would having a 3:73 rear end change anything???? I forgot to mention that in my original post. If I am reading the "charts" right that gives me a 21000 GCWR and a 10,100 payload.
Please correct me if I am wrong as I usually am with this stuff but.....assuming the worst case just for numbers and my "new trailer" weighs in at 14,000 even, would that mean I can only have 7000 lbs of truck, fuel, hitch, cargo and passengers? Does that not put me over my limit? I am assuming that with a starting dry weight of 12,5 it would not take long at all to reach 2000 lbs of food, water, dishes, clothes etc or am I WAY off base?
Also, how does payload factor into everything? Is that where the hitch weight gets deducted from? Now my head is spinning......
You need to get your weights correct.
The truck has 5 ratings...
Front and Rear GAWR (Gross Axle Weight Rating) the most the axles can weigh.
GCWR (the most the truck can weigh, most times its less than the added up axle ratings.
CCC (Cargo Carrying Capacity) how much stuff you can have in the truck, this is the difference between the trucks empty weight and its GVWR, cargo includes you, wife and anything you put in/on the truck including the trailers pin weight.
And finally you have the Tow Rating (how much your truck is rated to tow).
All this also applies to the trailer with the addition of pin weight.
Good luck!
Apr-07-2017 11:14 AM
Apr-07-2017 09:04 AM
fj12ryder wrote:
How far are you planning on moving this trailer?
I'm pulling a 15,000 lb. toyhauler with my 2001 Dodge dually. I simply don't see any issues with you pulling that trailer. Especially if you're only talking a one-time short distance tow.
The only real problem could, read could, be if you are under licensed for the combined weight, i.e. truck and trailer.
Apr-07-2017 08:54 AM
Apr-07-2017 07:31 AM
Apr-07-2017 04:41 AM
Apr-06-2017 08:49 PM
JnJnKatiebug wrote:rhagfo wrote:
Well assuming that you have a 2012 Ram 3500 SRW, you should be within all numbers towing that 5er.
If you are waiting for a 2102 Ram, can't help!
Maybe it is equipped with a flux capacitor.
Apr-06-2017 08:45 PM
Apr-06-2017 07:15 PM
Apr-06-2017 05:04 PM
Me Again wrote:
Watch your RGAWR. 17" tires if it has them have a low weight rating. Chris
Apr-06-2017 03:20 PM
Apr-06-2017 02:56 PM
Apr-06-2017 02:52 PM
