beelbill
Dec 25, 2015Explorer
Tow Vehicle
Have a 31 foot Cougar bunkhouse that has dry weight=7115 and load capacity=1885 for total weight of around 9000. My current tow vehicle is a 2007 Chevy Crew Silverado 2500 with tow capacity of 12,00...
KD4UPL wrote:
GM used to make a 2500 Suburban. They shopped a few years ago, quite possibly around 2012 which may explain the numbers your getting.
There is a rumor that they may be bringing back the 2500 Suburban, I've seen some of the spy photos and it does have 8 lug axles. If you can wait a while and see if that happens then a new 2500 Sub should do the trick.
Otherwise there really aren't any SUV options. You could possible find a used Ford Excursion but the V8 was too weak, the 6.0 diesel too problematic, and the V10 spit out spark plugs. The V10 would still be my pick if you go that route.
The problem is that either way, 8 people in a vehicle will just about eat up all the payload capacity before you even hitch a trailer. As suggested, a 3500 series van may work. Chevy used to put the Duramax in vans. If you can find one of those I think it would be your best bet.
I know some people like to always have newer vehicles and maybe you're one of them. But, there's no reason you can't get over 200,000 out of a modern properly maintained vehicle. Our 3 vehicles have 156,000, 184,000 and 205,000 on them and i have no intention of getting rid of any of them. They all run great.
