agesilaus wrote:
Look at the driver side door post there should be a sticker there which gives you some info. Primarily the payload capacity. Is that the empty weight of the trailer or the max weight. If it is the empty weight the actual weight will be more like 10,000# and the tongue weight will be around 1500#. Take the payload number subtract the weights of all passengers, dog, luggage, ice chest, misc stuff and a weight distributing hitch from that payload what is left over must be greater than the tongue weight.
As for the F150 the answer is maybe, it has to be setup with the right accessories, the max towing package and 17 inch tires. Even then I'm not sure if that would be enough.
To add to this:
Depending on cab configuration, power trains, transmissions, and installed options, payload capacity can vary (sometimes a lot) between two vehicles of the same make and model. F150 for example, has versions with as little as 750 lbs, and some with as much as 3200 lbs. There are some 1/2 ton vehicles that might tow that trailer, and many that could not. Unless the tow vehicle is an older model, it will have a tire / loading sticker on the drivers door post, showing the max occupant / cargo weight (payload) for that particular vehicle. Everything and everybody, you put in or on the vehicle, subtract from that max capacity to carry things.
Ten to fifteen percent of trailer weight, is actually (tongue weight) carried weight, as is the 80 - 100 lbs of WD hitch and anti sway equipment.
8500 lbs of trailer weight, with a weight distributing hitch, could eat up to 1375 lbs of payload. Add 5 - 600 lbs of people, pets, tools, etc, and you would need a minimum of 2000 lbs of available payload.
Most SUV's and 1/2 ton trucks, come from the factory with passenger (P) rated tires, which are designed more for comfort than carrying heavy loads. Compared to light truck (LT) tires, they have softer sidewalls, and are more susceptible to sidewall flexing. In severe cases, sidewall flexing can induce trailer sway.
