Towing in the wind.
rbpru
We just finished a 250 mile trip to down state Illinois. We had 20 to 25 + mph crosswinds all the way; so, we held the speed to 55 mph.
I was pleasantly surprised that the wind buffets were not that bad, but the gas mileage was a bit less than 8 mpg. :E usually it is closer to 10 mpg.:C Also at 55 mph everything passes you. We kept off the Interstate most of the way.
My TT is only 25 ft. and weighs about 6000 lbs. so it is not a huge wind sail. Still my driving sweet spot is normally about 60 to 62 mph. but it just was not working in the wind so slow and steady was the pace.
The question is, what speed works for you in a moderate cross wind, particularly the bigger TTs.
I am told the 5vers have less wind problems.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
35 REPLIES 35
ROBERTSUNRUS
azdryheat wrote:
Winds don't affect our toy hauler much at all. 35-40mph cross-winds and we're stable. 5th wheel towing is the only way to go.
๐Ÿ™‚ Hi, wind doesn't seem to effect us either. (Airstream)
๐Ÿ™‚ Bob ๐Ÿ™‚
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
azdryheat
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Old-Biscuit
We shut it down if winds are forecast to be above 35 mph. Our 5vr is 13'4" and IS a big wind sail
High profile vehicle wind warnings are issued when wind speeds are expected to reach 45 mph.
Steady wind can be dealt with it's them sudden 'GUSTS' that get ya!
SDcampowneroper
You did right, took your time and protected your family and those behind otherwise in a hurry that did not like waiting behind you. Ofttimes the slow way is right. Cudos!
kknowlton
In the wind speeds you mentioned, we would probably have slowed to about 55 as well. Generally speaking, we draw the line at winds over about 38 mph, especially if they're crosswinds. We'll just stay put when they get too high - it's not worth the white knuckles. As Scott pointed out, winds can blow you over. For extra stability towing, as it's almost always windy where we have lived, we usually fill the freshwater tank at least 1/3 before leaving home - good ballast.
Yes, gas mileage will drop into the wind. Anything that's taller than your tow vehicle is a sail. No experience with 5ers, but I would guess some of the big tall ones would be even worse in that respect, though they might possibly handle a bit better in wind.
2020 Toyota Tundra CrewMax 5.7L V8 w/ tow pkg, Equal-i-zer
2020 Lance 2375
ScottG
Too many variables, you just have to get a feel for what works for you at the present.
But keep in mind that the wind can blow you over if it's strong enough and the faster you go, the easier it is for the wind to topple you.
