towing torque converter
abyars111
I'm about to have transmission rebuilt, it is a Ford C6. I've been reading about towing torque converters. TCI, Hughes and a few others make some.
Has anyone here used one of the towing specific converters?
5 REPLIES 5
abyars111
Thanks. No, I think I just need the gas towing convertor. I'll be towing a 5850lb camper at highway speeds, 55-60 mph.
4x4ord
abyars111 wrote:
Thanks for the input. I've been leaning toward a Hughes converter. Did you notice any difference at idle, do you have to apply more brake pressure to hold the truck still?
It doesn't require more brake pressure to hold the truck at idle. It has a much lower stall speed, though, which is what I needed. My application requires heavy pulling at speeds below 10 mph so I used a planetary gear set out of an overdrive transmission. If memory serves me right my first gear ratio is 2.72:1. You might not want the diesel converter for your application.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
abyars111
4x4ord
I built a 460 ci Ford for a truck that was used for off road work. The 460 was bored and a stroker kit was used to bring the displacement to 535 ci. I coupled it to a C6 with a Hughes torque converter that I have been very impressed with. Against Hughes Performance recommendation I went with their diesel F43XFM converter. They told me the diesel converter would "hook up" too quick and I wouldn't be happy with it; but I am.
B&W Companion
sidewayzz
http://www.gopnh.com/, They come highly recommended from some guys. I just had mine rebuilt and the builder who is well known for building heavy duty trans said save your money and buy a good reman and I would be good to go.
2006 dodge ram 2500
forest river heritage glen
wife and three kids
