jdgilbert
Feb 22, 2015Explorer
Towing with 1/2 ton SUV NEED ADVICE
I own a 2011 Yukon, 116" wheelbase, 5.3L, 3.42 ratio, with HD tow package, tow rating of #8,500. I'm looking at buying a TT but am unsure about how much of a trailer my vehicle can safely handle. I am considering the Jayco, White Hawk Summit 28DSBH. According to the numbers I should be able to pull this but would like to hear from anybody who may have more experience towing with a shorter wheel base SUV. Trailer Specs are:
Unloaded Vehicle Weight - 5,460 Lbs
Dry Hitch Weight - 635 Lbs
Gross Vehicle Weight Rating - 7,500 Lbs
Exterior Length - 31' 11"
This camper has the spread axles, not sure if this will help with handling. I would definitely be using a WD hitch with sway control.
