It will do it, albeit since older, a bit slower up the steeps
Waiting for mine to die or wear to the point just have to rebuild... :B
Will keep mine for a long while. Hate payments, can afford to buy one out right, but their prices are insane to me. It is a truck to me, not a car. Know that trucks are designed with margins for work, not like cars...
I have 4.1's and suggest you consider it if it doesn't have it now
Flush EVERYTHING with synthetic. Mine has been on synthetic's since new and MolyB (2 micron) additive in everything except except for the 4L80E and Diff (anything with clutches will be ruined with such a low co-efficient friction modifier). Make sure power steering (also is the power brake source) and MC (DOT4, non-silicone)
Change out the engine thermostat to a 180* and I've drilled a 3/32" dia hole in the flange...as the tiny <1/64" dia OEM hole is too small and temp over shots when really, really hot)
Change out the fan clutch to a 'SEVERE' duty. OEM is 'standard' and some have found to have a 'HD'. HD and severe duty fan clutch of that era couples up to 90% of shaft RPMs. Standard best is around 50%-60% shaft RPMs are coupled. Also, since so much is coupled...the bearings are beefier and SEVERE duty has the biggest bearings. It will ROAR when it kicks in and surprised me the first time. Can see the dash temp gauge needle drop like a rock when it kicks in
Know other TV's computers have backed off via their torque management and mine still provides 'Power Mode' when they start to slow...of course naturally aspired...forced fed has that advantage and if they have a good cooling system with lots of margin... Also, mine handles...more so compared to newer which are so tall because the fashion statement crowd thinks taller is more capable...my track is +10.5" wider than stock to boot, so cornering is something different...
Make sure the radiator has the 'short' neck and is in good order. The 'short' neck has the 7 fin ATF, in tank, radiator (liquid to liquid).
Depending where it has been parked/kept/etc...leaf & debris build up between the AC and radiator partially blocks air flow. Creates mystery heating/cooling issues. I blow mine out with 100 PSI air every so often
Duct tape the intake holes on the engine bay side of the air ducting to the filter box. I've made my own ram, cold air intake that is in parallel to the OEM intake routing.
Keeping the intake charge important to always have power mode available.
Change out the air filter with the OEM optional "HD" and just drops into the OEM filter box. It is about 2" larger in dia.
Read diff is the EXACT same as the 1 ton dually of that year...except for the cylinder and MC (dia's are larger and DO NOT lose the short rod between the MC and booster...almost impossible to replace and is a junk yard thing) and change them to that 1 ton dually
Check if you have the 3.5" wide rear shoes...those are the same as the 1 ton dually...mine came that way and why parts folks always ask how wide your rear shoes are....no matter what
Manually adjust the rear shoes often, as the proportioning valve is off....not sending enough to the rears. Decided to NOT touch that and just manually adjust them
Pulling is common and is due to the rears not in the braking game...in a pinch...apply the E-Brake pedal a bit to move the shoes into the game
I like Praise Dyno, but the GM Parts "Dura Stop" rear shoes almost as good to provide "Nose Bleed Braking"
Super Tune the fronts...as the slides stick...I've made a special grease gun with a hypo needle to poke in high temp brake grease (filled with MOLYB)...and make sure to change out the slide O-Rings
Spark Plugs...have modified with by 'cutting back' the ground electrode
SS WIRE ignition RF suppressed wires...I like copper over Platinum plugs and change them around 50K miles or so
Copper inserts on the dist cap::Gater Back serpentine belt
Change the Serpentine tensioner...they typically last in the 60K miles or so for me
NOTE that the newer TVs, not just GM but most all, has "Torque Management" and this era Suburban does NOT, so it runs with that pack well, or at least mine does...to even taking them when "The Boy Racer" kicks in when challenged by another Boy Racer...
Know that there are most things forgotten and will noodle that for a while...
Plans for the day that, gosh darn, just have to rebuild...
- A 'built' engine that will pass 1996 SMOG, I live in SF Bayarea
- 1,000 HP 4L80E, but only going to use less than half depending on what the engine builder can do and still pass SMOG...so it will last a looooong time...these 1K HP unites are warrantied for 3 years, so going to last
- A gear spliter OD with a 0.75 OD ratio...gear spliter, so it will insert itself in-between each gear to make 8 gears...times 2 in LOW
- New diff ratio in the 4.8 or maybe 5.x for a final double OD to the axles in the 2.x range
All of the Internet searches finds +500 HP 454's, but are for carberators...no good ones found to date for a Vortec...yet...or will bite the bullet and have one built. Engine builder passed on and am looking right now
Also, if it has the F60 option (check the glove box label listing all options it left the factory with) and you will have a 'Snow Plow' prep package that begets 1 ton front torsion springs. Since it comes with the 6,000 RGAWR as the 1 ton dually of the same year...tongue'n cheek refer mine as a K3500 Suburban...
If me...I'd buy it and have two Sub's and make the choice of which one to be the parts one...
![](https://i.imgur.com/gv4Y1wF.jpg)
mysub mysuburban
