Towing with Lance TC:
DesertMax
I've been looking at a new to me rig and need to be sure I can tow with it. This one is a Lance LC480 9.6 which is the length I need but it has the rear bumper that looks like it covers the entire lower area of the truck including license plate and receiver.
Can anyone tell me if without actually loading it up, there is any way to know for sure if this is the case...
Where ever I go, there I am!
20 REPLIES 20
nomadictxn
Lance actually touted this model and the newer 915 as practical for towing. I have a 480 on a 11 2500hd Chevy. I have a clear shot from the factory receiver, under the camper bumper. And yes it does hide the plate. I have never bothered to take plate off and put on camper. That will probably change if I ever get a ticket. The previous owner set his truck up to tow with the 480. He used the camper 3 times and moved it around his yard for 20 years. I found it on CL and picked it up pretty cheap. Not a bad camper.
nomadictxn
2013 RAM 1500 QC 5.7, 3.92 4x4 6 sp.
2021 Flagstaff E Pro 19FBS
NEOK
If you are going to tow it is hard to beat the Torklift Superhitchg and SuperTruss combination. This provides a very strong and stable combination with no sway on our boat trailer.
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
DesertMax
Can you tell I have sleep apnea... Explorer makes it sound so easy and of course... it is.. Now why didn't I think of that.. Basic math can be so complicated sometimes..
the seller swears that he got it from a guy with a Super Duty truck same type model year as mine and it didn't cover but I know he is wrong..
I've seen plenty of those with the built in step going down the road and they all have the license plate holder... and much more weight..
Thanks guys..
rlb8s
I had to use a hitch extension with my Lance 915 when towing. I didn't invest in the high dollar super hitch but rather just an 18" extension I purchased through Amazon. A hitch extension like the one I used will lesson your tongue weight capability. The extension worked fine, but I would have been better off with a super hitch.
12 RoadTrek 210 Simplicity - named E-Pod
05 GMC 3500 SRW Crew Cab LB
10 Bass Cat Puma w/ 250 Mercury ProXS
Previous RVs -
14 Livin Lite 8.6
13 Pleasure-Way Lexor TS Class B
13 Tioga Montara 25K Class C
09 Lance 915 Truck Camper
trail-explorer
Measure from the bottom of the camper to the bottom of the bumper. Compare that measurement to the floor of the truck bed, that will show you the clearance.
Bob
Buzzcut1
Nomad II
Nomad II
it will cover the plate which is why lance has a lighted plate holder on the back of the tc. you will need a hitch extension to tow. most of us uese a torklift super hitch plus a super hitch supertruss extension
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
