Towing with Toyota Tacoma
john_d_dobbs
I'm considering a new truck, perhaps a Toyota Tacoma. How much do you pull (would you pull) with a new V6 Tacoma with auto trannie? The towing capacity specs are towing capacity 6400 lbs and tongue load 640 lbs.
Thanks,
John
20 REPLIES 20
GWolfe
There is a member on here, profdant139 I believe, that tows all over the west with their Tacoma. I would search for posts from them to get a good answer to your question.
I think a Tacoma would be a fine tow vehicle for a smaller travel trailer, just watch the specs.
2005 Sun-Lite Eagle
2011 Silverado
blt2ski
Moderator
Moderator
my son has pulled my 6000 lb equipment trailer out of his back yard for me on more than one occasion with his 4 banger taco! Then again, he has a locker, 4wd. My non locked rwd 3/4 ton is rather useless when the grass is wet!
At the end of the day, if you have enough payload for what you are doing etc, go for it! It may not be the quickest thing out there. But it will get you to the camp spot safe and sanely assuming you are within the warranty ratings.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
dhull
Pulled a 3500lb boat with my 05 4WD tacoma. No problems just have to give a little more room for braking. I did add a transmission cooler.
goducks10
bgum
John that is exactly what we did. We went from a Tundra and 23 ft Airstream to a Tacoma and a 16 ft Airstream. Our Tacoma fits our needs at this point in life.
By the way there is a YouTube video comparing the Tacoma to another truck towing the Ike Gauntlet. It covers towing a loaded trailer and braking.
john_d_dobbs
Thank you for everyone's thoughtful comments. We are retiring and downsizing seems to be a theme - the Airstream Basecamp at 2500 lbs would seem to fit with the Tacoma.
Thanks for your help,
John
Ralph_Cramden
ib516 wrote:
For occasional towing within the specs, it will do fine.
Hey! Please do not use common sense here LOL.
The OP needs an F450 at least.
Too many geezers, self appointed moderators, experts, and disappearing posts for me. Enjoy. How many times can the same thing be rehashed over and over?
kw_00
My dad has a new Taco with the V6 and pulls the Gulf Stream vintage 19 ERD camper. He has pulled all across Florida and Georgia so not much in elevation until he gets to the mountains. Heโ€™s happy with his set up, Iโ€™m sure the tundra would do it better. He has not said anything about trading up or changing the truck out so thatโ€™s his take. Itโ€™s all up to how much your pulling, Iโ€™m sure the truck will be fine within itโ€™s pulling specs.
A truck, a camper, a few toys, but most importantly a wonderful family.
Grit_dog
Navigator
Navigator
N-Trouble wrote:
At your altitude and terrain I would want a little more truck. My father in law has an 08 and just pulling a UTV on a single axle it struggles at altitude.
This, especially if you're thinking about a TT anywhere near that limit.
twodownzero
I would not pull more than 2-3000 lbs. with a Toyota Tacoma (and would not tow anything with it regularly). I had a Ford Ranger for years, it was a great little pickup, but it was absolutely horrible even with a tiny single axle trailer behind it, downright scary at times with others, like a 6x12 u haul trailer. A mini truck is not a tow vehicle. If you're buying a truck to pull a trailer, buy something that is made for towing, not backcountry adventures with a few passengers in the truck.
N-Trouble
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Bionic_Man
I think it would be fine for a pop-up, or some of the small teardrop/hybrid TTs. I think I would stay below 5000 pounds (and your hitch weight will likely limit you below that).
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
jerem0621
I would buy a Tundra if I planned on pulling anything other than a PUP or a utility trailer.
JMHO
thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
bgum
We tow 3500 Gvwr with 378 hitch weight 16 feet with 2018 Tacoma long cab short bed. We use sway control but no weight distribution. It tows well with plenty of power.
