โJun-22-2016 06:38 AM
โJun-24-2016 08:22 AM
โJun-24-2016 07:40 AM
Bigmac8 wrote:
Original OP here. Sorry I caused such a ruckus. I was referring to the top of the ball and the top of the socket on the trailer tongue. My wording was not correct. So if the truck is level and the trailer is level is the ball higher or lower than the socket without the wdh set up. If the ball us 1 " higher the truck settles much lower after the the tongue jack lowers takes the weight off it than if it is level with the top of the socket before the wdh is set. Thanks again for the info.
โJun-24-2016 06:33 AM
โJun-23-2016 07:40 PM
beemerphile1 wrote:I read it the same way you did. I wish the OP would clear up the question.
... Here is the OP:Bigmac8 wrote:
Been lurking here for months soaking up,the info like a sponge. Simple question that I have saw many answers on from posts and videos. Is the top of the hitch ball supposed to be level with the top of the receiver when backing up to hitch up. Or is the ball supposed to be 1" or so higher. Have used both ways but looking for the correct install. Thanks for the help.
The questions are in bold. I answered the questions asked.
Reese Dual Cam Straight Line HP Sway Control
โJun-23-2016 05:17 PM
โJun-23-2016 04:35 PM
โJun-23-2016 04:08 PM
โJun-23-2016 12:20 PM
โJun-23-2016 10:45 AM
hohenwald48 wrote:
I think if you read a little closer and use a little understanding, you'll see the "receiver" he is talking about is on the trailer. Obviously, he was not referring to the technical "receiver" you made reference to. I elected to not make a big deal over his failure to use the exact terminology. You apparently thought pointing out that little error would be helpful in some way. I'm now done with this thread.
โJun-23-2016 10:25 AM
โJun-23-2016 09:07 AM
hohenwald48 wrote:
Are you aware the OP asked about ball height. Never mentioned receiver. Why would you even add that bit of worthless info to the thread.
The relationship between ball height and tilt of the driver seat is meaningless too. And about as relevant as your "receiver" statement.
โJun-23-2016 08:53 AM
โJun-23-2016 05:19 AM
hohenwald48 wrote:beemerphile1 wrote:
The relationship between the ball height and the receiver height is meaningless.
When backing up to hitch you obviously need the coupler to be higher than the ball so the ball can go underneath.
Not true. If they are not the same height when both are level before hitching you will end up with one or the other (possibly both) going down the road unlevel. ie; nose high or nose down
Of course you have to raise the trailer tongue above horizontal to make the connection. Common sense.
Setting the proper "at rest" ball height is necessary to have a level trailer and tow vehicle while towing.
โJun-22-2016 09:09 PM
