โJul-27-2014 03:53 PM
โJul-29-2014 08:37 PM
rbpru wrote:
I guess if to have the right floor plan and a TV that can tow it you are set. Then the rest is the luck of the draw.
We would like to think that a newer TT would be an improvement over one made 15 or 20 years ago.
I hope you have many long years of service. Keep in touch and let us know.
โJul-29-2014 08:02 PM
โJul-28-2014 07:20 PM
rbpru wrote:
As far as I can tell most trailer manufacturers use the same major components from just a couple of sources. If you are looking for a cost competitive model that is head and shoulders above the next you probably will not find one.
From what I have seen there is more difference between a companyโs low end models with few amenities and trim and their high end models with all the trimmings; than there is between manufacturerโs models in the same price range.
When you have the same components, work force, and construction techniques between companies there is not a lot of room for cost variance. Stick and tin, fiberglass or the various composites all have advantages and disadvantages.
Contrary to popular belief RV are not rat traps held together with bubble gum and angle dust. They are designed to be hauled down the road at high speed, in wind, rain, and heat and cold. Try that with your house. They are however pounded out as quick as possible with little concern for letโs say old world craftsmanship; from materials purchase from the cheapest bidder.
โJul-28-2014 02:49 PM
โJul-28-2014 01:26 PM
โJul-28-2014 12:06 PM
โJul-28-2014 10:29 AM
Doug33 wrote:
I've never owned one, but I find it ironic that the salesman tried to steer you away from a Jayco, yet many people here on this forum have said their Jaycos are some of the best built TTs.
โJul-28-2014 09:32 AM
โJul-28-2014 08:16 AM
โJul-28-2014 07:27 AM
โJul-28-2014 07:17 AM
westend wrote:
The difference in price is probably reflecting the initial retail price and has little to do with quality. Stay on the Forum a bit and you'll see that folks have just about as many problems between different brands and between different ages of trailers.
There are a few brands that hold value better like Airstream, Avion, Scamp, Oliver, and some of the other fiberglass trailers. That has to do with the exterior skin and perceived longevity more than anything.
Your Keystone has Torflex axles and that, IMO, is an upgrade to conventional springs. Enjoy what you have, you got a fairly good deal. Make sure your roof penetrations, windows, and corner trims are sealed and you'll get a lot of use out of your Keystone.
โJul-27-2014 10:18 PM
โJul-27-2014 09:41 PM
โJul-27-2014 09:22 PM
rmnpcolorado wrote:
I find it interesting that you're asking people on an RV forum what they think of two manufacturers - my question back to you is what did YOU think of the two different manufacturers' products? You're the one that looked at both of them, how did YOU think they the two models compared in build quality? If you looked both over thoroughly, it should be fairly obvious the differences, even in used trailers. I myself have a different opinion than what you came back with as I happen to like Jaycos. Having said that, I know there are other units that are built better than Jayco, and my next trailer will probably be a different brand that I like the build quality better on (currently eyeing up the Lance line, even though we have a dealer nowhere near us!).
To me it's about what YOUR opinion is of the manufacturer and trailer you're looking at (because each is built different individually as well). And if you bought used, it gets even more interesting.
