Carb_Cleaner
Jan 16, 2014Explorer
Trailer wire harness
Splitting the trucks 7-pin into both 6-pin TC plug and 4-pin trailer plug. What are you guys using? Fabricating a harness? Torklift's expensive splitter/extension? We'll be pulling a 6x12 enclosed, no brakes, but a handfull of running lights plus brake and license lights. All are incandesent, as are all the lights on the TC. Do I need to worry about amp draw? Is it better to switch to LED running/brake lights? What about some kinda relay array? How about a booster instead of LEDs, like this:
http://www.etrailer.com/Custom-Fit-Vehicle-Wiring/Tow-Ready/119192.html
I have a factory, 2013 Ford connector on the truck and the 7-pin to 6-pin, about 10' long, cord that came with the coach. My cargo trailer is 4-pin. We will not be using a hitch extension, so I don't need the Torklift unit's longer wires. Sources for cheap components to make a harness or links for reasonably priced ready-made would be appreciated. I'm not afraid of a soldering iron or shink tube and I haven't checked what gauge wire the factory used. I guess I know enough to be dangerous, but that's about it.
Thanks
Thanks
