SweetLou wrote:
dodge guy wrote:
That’s normally a fluid change. Our Ram truck 8 speeds will hang up in 2nd gear when coming to a stop. Changing the fluid fixes the issue. Anyone that believes in lifetime fluids is asking for a large repair bill. The fluid is expensive, but it’s still cheaper than a trans.
So I have the Ram 2013 68RFE Trans in my truck. I read some scary stuff on what is weak and can go wrong. Would a flush and filter change be a good preventative on these issues? I bought my truck used with 36K on it from the dealer back in 2015 and I made him flush and service the trans or I wouldn't buy it with out knowing anything about issues. So, if you recommend doing this, with which brand of fluid to replace it with?
68rfe is nothing like the ZF 8 speeds.
Read IdaD post about his accumulator retainer. That imo is the one fatal flaw weak link.
As much as I don’t like them, they are about as reliable as other units, only clunky and Shift poorly.
You don’t mention how many miles since last service. So impossible to give a recommendation, but I wouldn’t go more than 60k between services. I also can’t see your trans fluid, which is the real indicator.
