Farm_Camp
Aug 20, 2013Explorer
zul wrote:Farm Camp wrote:.
Pic Clicky
Is that the seem where the roof meets the sidewall?
Yes. Most of the rubber roof top tucks into the sidewall rail pretty well. This is one spot (about 3-4 inches long) where it is coming out a bit.
Basic Silicon caulk? Some sites say to not use Silicon only special RV Roof caulk. Is there something at a regular ACE or off to a special RV shop?
Yah. Others I'm sure will be along shortly with better advise than I can give you. I'm not sure if you could just loosen the side rail or remove it and tuck the roof material back under, seal it with some butyl tape ( I think they call it) and replace the rail with the rubber tucked away again. Hopefully water has not already got up under there and swelled or rotted the sub roof.
44,026 PostsLatest Activity: Mar 03, 2025
