Aug-04-2018 07:57 PM
Aug-06-2018 05:16 AM
Aug-05-2018 11:56 PM
Aug-05-2018 11:06 PM
SidecarFlip wrote:wnjj wrote:
Especially fun are the comments about braking performance from someone who drives a more than 20 year old vehicle.
My 20 year old vehicle has the rear disc brake conversion with Girling twin piston calipers, vented and slotted rotors, same on the front with EBC HH High friction pads all around. I run EBC because I sell them and they are excellent pads.
No lack of stopping power at all. In fact I can slide all 4 tires on dry pavement with the camper in the box cannot do any better than that.
Next....:R
Aug-05-2018 10:31 PM
wnjj wrote:SidecarFlip wrote:It sounds like you’ve got your truck modified to work much better than stock. So is the takeaway from this that one shouldn’t make assumptions about a vehicle’s capabilities without knowing the details?wnjj wrote:
Next....:R
Aug-05-2018 09:17 PM
Next....:R
Aug-05-2018 06:18 PM
Aug-05-2018 06:14 PM
Aug-05-2018 04:20 PM
Aug-05-2018 04:08 PM
Aug-05-2018 03:59 PM
Aug-05-2018 03:52 PM
Aug-05-2018 03:31 PM
Bedlam wrote:
That is a 4500 lb Host Everest (dry weight) on a long bed crew cab Ford. The rear axle has a 9750 lb OEM rating and with Vision rims gives him 9000 lbs of it available with PR16 LRH tires. Expect the truck to weigh 3000 lbs on the rear axle when unloaded, so he has about 1500 lbs for water and gear. Flat towing behind it adds almost no tongue weight.
Aug-05-2018 01:22 PM
Aug-05-2018 11:51 AM
SidecarFlip wrote:Old-Biscuit wrote:SidecarFlip wrote:
If you look closely at the picture, you'll notice that the truck is squatting a bit in the back. Bet the fridge isn't level....lol
IF you look closer you will see lego lynx blocks under Front wheels to level truck/camper
You have better eyes than I do. Don't see anything.
