In the tech folder, there are a few threads discussing camper dollies. I looked at just about every design, including pre-fabricated and decided to follow another member's (Spott) path ... using a farm wagon running gear as the platform for my TC dolly. I didn't go with a wood frame like he did but instead chose to have one welded up. See linky for Spott's dolly:
Farm Wagon Running Gear Based TC DollyI'll post a pic up in the Spring once I paint mine. I wanted something that would handle (and not damage) asphalt, cement, gravel, grass and whatever else with ease. That pretty much knocked out any caster based dolly. Here's what I did:
- Bought an old (circa 1940's) 6 ton farm wagon running gear - $100
- Needed 4 new tires ... bought 4 almost new used, low profile snow tires for - $100
- Welding (incl. materials) to fabricate an angle iron box frame (open bottom) - $250
- Still to go, paint, maybe a plywood floor - $100'ish
Total investment will be around $550 with a plywood floor, less than $500 without the floor. BTW - I'm thinking a platform floor to help keep the critters out.
I ran out of time to finish it (paint & floor) this fall but still used it to load and store my TC on this winter. It is super solid, very easy to maneuver by hand or hitch with the running gear pin tongue, rolls over everything on the 15 inch passenger tires and ... the wheel assemblies and steering mechanism are grease-able.
After painting it to match my TC colours, I'll also be dressing it up with a set of Chebby hubcaps even though the TC is hauled with a Ford. It wasn't that hard to put the pieces together and everything I sourced came used from Kijiji (like CraigsList).
