Truck capacity
odyknuck
Ok I want to match a Truck Camper to my 2013 F250 6.7 diesel with 8' bed. There is a sticker on the door that states tire specs and max payload of 2365#s.
Am I to assume that is the max load for the factory supplied tires or for what ever tires are on it? The GVW is 10K for the truck. The axles are front 5900 and rear 6100#. I also want to tow a 28' cargo trailer behind that could weigh up 9100#. Please advise.
"Make life better, relax and adjust to enjoy"
44 REPLIES 44
odyknuck
Hmmmm! Well this thread went to crap! lol
SugarHillCTD
John & Cathy
'12 Chevy 2500HD CC 4x4 sb
'16 Cougar 25RKS w/ Andersen rail mount
'13 Eagle Cap 850 (sold). B4 that a few other TCs and a TT
twodownzero
It's all okay if the camper manufacturer says it's okay. Like my Lance 815, which overloads my 1 ton single wheel...apparently it's okay for a 1/2 ton.
Bedlam
Moderator
Moderator
Nah, you just need really low skid wheels with high speed bearings to carry the excess load.
Reddog1
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
deltabravo
805gregg wrote:
Maybe a Lance lite camper to increase your towing, don't need a dully unless you like to buy 6 tires at a time, and want to run those ugly fenders into everything in sight
The point of this thread is to ask about campers, not debate the dually vs SRW thing.
If someone has a dually "and runs in to everything in sight" then they have no business even driving, let alone hauling a camper.
I've never hit anything in 39,645 miles of driving my dually.
twodownzero
FireGuard wrote:
A Lance 815 or similiar would work well.
8' so no overhang and around 2k lbs loaded. This would allow passengers, cargo and likely 800 lbs or so of trailer toungue weight.
2k loaded? You must be kidding. My 815 is 2400# empty!
Bedlam
Moderator
Moderator
When I priced out higher capacity 18" tires and rims, the cost was not that far from 19.5's. If I was going to upgrade and spend the money, I wanted sufficient capacity for the money I was going to spend.
Wheelholder
You can go to an aftermarket rim dealer. They have the capability of telling you what the max loading are on their rims. I put a set of American Racing Daggers on my 2500. They are rated for 3900#. The nitto's are only 3750#.
2008 Silverado crew cab Duramax/Allison
2008 Lance 830
Oldme
A good info page here:
http://www.visualsc.com/tc_calc.htm
Bedlam
Moderator
Moderator
https://www.fleet.ford.com/truckbbas/non-html/2013/2013FSeriesSD_Pickups_SB.pdf
Page 23 of 26 will show you the OEM ratings of each rim.
odyknuck
How do I find that out?
ticki2
Not unless the wheels are also rated for 3750# .
'68 Avion C-11
'02 GMC DRW D/A flatbed
odyknuck
Ok, I am looking at LT285/70R17 with a load rating of 3750#s. The stock tires are rated at 3195#s so does not that bring the payload level from 2395 to aprox. 3500#s?
