Jul-05-2015 11:02 AM
Jul-09-2015 06:14 PM
Jul-09-2015 07:25 AM
Jul-09-2015 06:33 AM
Jul-06-2015 01:04 PM
Jul-06-2015 08:36 AM
Jul-06-2015 08:08 AM
Jul-05-2015 09:36 PM
trailgranny50 wrote:
My hubby is 72 and has a few issues as a brick mason but still manages the steps ok. We have a cargo tray custom built with steps that is much easier than a long row of scissor steps but or truck is an 04 Chevy 3500 and sets much lower than the new trucks. The larger issue is climbing into the cab over bed. As long as he can manage that will keep the TC. That being said we have discussed the small travel trailer or class B+ motor home to get a permanent bed at a lower level but this rig is paid for and we're still able to get up in both the camper and bed. You do what works for you.
Jul-05-2015 09:34 PM
garycq wrote:
I have tried to change my signature and what is on it but I haven't been able to. My signature should read:
2007 29-5T, 125 Solar Panels, Inverter, 5th Airborne Sidewinder Combo, Brake Smart Controller, Michelin 16" XPS RIB tires
2001 Dodge CTD 2500, LB, Dana 80 4.10, AirBags, Smarty, DTT Trans w/Smart Controller, Mag-Hyrtec Trans & Differential Covers, 4 inch Exhaust, PacBrake, 60 Gal Tank
Gary
Jul-05-2015 06:02 PM
Jul-05-2015 05:39 PM
Jul-05-2015 05:32 PM
Jul-05-2015 04:52 PM
Jul-05-2015 04:50 PM
KD4UPL wrote:
I don't think a single person, particularly a male, would load an 8' TC with 1,000 pounds of water, food, and gear. If you were taking a wife and kids then that would be likely. I suspect you might only add 500 to 700 pounds of stuff.
Jul-05-2015 04:42 PM
Powerdude wrote:
Those are 3500 duallies, so even if the pin weight is 4000-5000 lbs from a gooseneck with 20k lbs worth of cars on it, plus the 2k for the weight of the trailer, it's still within spec.
