ssemaloneExplorerFeb 01, 2014TT batteryWhat is the best way to keep the TT battery charged when not on the road?? Plug it in like the boat, use a trickle charger??
prichardsonExplorerFeb 01, 2014A good condition battery will easily hold its charge for a month or so if it disconnected. I do as Tvov does and haven't killed a battery yet. If you do chose to keep any type of charger on the battery be sure to check the water level often.
Related ContentCharging battery on TTbattery issues on new TTLeave TT plugged in or remove battery?First TTCharging TT Battery with Honda 2000 Watt Generator
