Ttailer weight
svytlana
So ive been using a small flatbed to carry 3 atvs. Im thinking about upgrading to a 20 foot enclosed trailer. Wondering what the expexted tingue weight is on these. Im using a 21 inch super truss now. Would i need a wdh? Truck is an 02 1500hd and im carring an 03 elkhorn lt 8.6ft. Weighing about 2300lbs
28 REPLIES 28
svytlana
Here are the truck specs. Same front end as the rest of the hd's 4500lb. 6000lb rated semi floater rear gm has used for ever in there 2500 series trucks.
www.thecarconnection.com/specifications/chevrolet_silverado-1500hd_2002_crew-cab-156-0-wb-4
I have the super hitch, super truss setup. Torklift tie downs. And airbags. Hauled from washington to denver last summer and went over vail to moab on the way back. Truck did great except gas milage with the 4:10s sucked.
deltabravo
svytlana wrote:
Would i need a wdh?
Yes.
I'd be concerned with the tongue weight and camper putting the truck over it's GVWR.
I think the 1500HD of that era has a GVWR of 8600lb
burningman
The gas Chevy won't have any problems with power. I keep reminding you guys, not that long ago all we had were gassers. And we carried all sorts of things.
Your advice loses credibility when you say things like only a diesel can pull any weight. Yeah they do it better, but its not like gas trucks can't get work done.
He's got a small light camper and some ATVs. get real.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Grit_dog
Navigator
Navigator
It'll do it, but not happily.....or quickly. Wdh on a truss hitch just screams get a different truck or a different hobby.
SidecarFlip
I'd be concerned more about the drivetrain, especially if it's a gasser.
I know one thing, if I ever bought a used pickup, if it has what appeared to be a used receiver hitch, camper tie downs or a fifth wheel hitch in the bed, I'd run like hell.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
svytlana
So i have 2 250cc atvs and one 125 china for my son. Was looking to add a 50cc one. What about like an 16-18 ft. Wiuld they fit?
svytlana
Was looking for real world weights of enclosed trailers. Looking online and from previous experiance. They say empty the have 300lb tongue weight. So probly 500lbs with the wheelers? Dont know anything about weight distribution hitches. Do they even have them rated for that little?
Bedlam
Moderator
Moderator
My 20' enclosed trailer rated at 10k lbs weighs over 3500 lbs empty with about 500 lbs tongue weight. When I have mine loaded up to 8000 lbs, the tongue weight is over 1000 lbs.
svytlana
The 1500hd is a 3/4 ton truck. Yes 6000lb rear axle. Truck empty has like 2500 on rear axle and camper loaded is like 2300. Current tongue weight is probly like 250, i can lift it by hand.
KD4UPL
You've got 2300 pounds in the bed of a 1500 plus pulling a trailer now correct? And you want to go bigger correct? Have you weighed your rear axle with the current set up? If I remember correctly a 1500HD has an 8 lug rear axle but I can't imagine the RAWR is much more than about 6,000. I suspect your close now. I wouldn't be adding any weight with a heavier trailer.
d3500ram
OK... I will acknowledge the 1500 gorilla in the forum....
I think you are asking too much from a 1/2T series truck especially when adding a 20 foot enclosed trailer.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
burningman
ATVs don't weigh a lot but 20' enclosed trailers do.
I'd use a weight distributing hitch for sure, towing one with a half ton carrying a camper, and towing on a hitch extension too.
svytlana
500, 400, and the kids is like 200. Also might add a 50cc one for the youngest. Would be nice to have a place for the campnchairs and extra coolers and the like that is lockable.
jimh406
I'm sure Bedlam or boatycall will respond, but how much do the ATVs weigh?
