Tv install
spitts55
Is there a kit or miunt that i use to install a tv in travel traile there is a space for it .thanks
3 REPLIES 3
CincyGus
X2 on monoprice.com
I've bought about5 mounts from them for my house along with sister and parents. All worked well, were cheap and came with plenty of mounting hardware for multiple options.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
Campfire_Time
As handye9 said, there are so many different setups that there is no standard. Just do what works. Our old trailer had a folding shelf for the TV so it could not be permanently mounted. I used a removable monitor arm from Monoprice.com and just took it all down when traveling. In our X20E I found the arm still works great, but now I can just leave it clamped in place and remove the TV when traveling. There is a mount or arm available for every conceivable application.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
handye9
No standard kit or mount. All depends on TV size and location of the install. Some flat wall mounts, some with articulating arms. Many folks (myself included) have used standard household type mounts. Then used varying hold down systems.
On one of my trailers, I run a lashing strap behind the mount. The screws into the wall secured both the mount and the strap. When going on the road, I push the TV tight against the wall and cinch up the strap.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
