esox07's avatar
esox07
Two questions: Hub temp and hitch lube
OK, two days until I leave for my trip from Wisconsin to S. Texas and back towing my 19' KZ Sportsman. It is a single axle trailer and since this will be my longest trip with the trailer by far, I am planning on stopping to check a few things every so often along the way. Tires, pressure, hitch, oil, tranny temps, etc.... I also plan to check the hub temps every few hundred miles. I have an infrared temp gauge but I have no idea what temps I should be concerned about. I pulled the bearings, inspected them and lubed them back up this spring. I don't expect any problems, but I want to be cautious.
The other question I have is this: Is it a good idea to put some lube on the hitch ball and coupeler or will that just attract more debris and make it worse?
So, lube the hitch or not and max temp for trailer wheel hubs???
Thanks.
