Under mattress treatment pj
pjay9
As you know I am doing a rebuild of the 1161 Lance. As per my request the new cab-over bed will have raw wood finish. I am wondering what others have done for variuos issue under their mattresses?
I installed foil faced bubble and fiber batts used to make quilts and a denim fabric cover it looked good and did the job, that was over the original Lance black thin fabric. I get to start fresh.
IDEAS, PLS!!!! THANKS.
2005 Lance 1161, 2004 Dodge CTD 3500 Dually 19.5's Stabiloads Roadmaster Sway, 2009 20' Raider 185 Pro Fish 90hp & 9.9 Yamaha vintage Penn elec.downriggers EZLoad roller trailer
12 REPLIES 12
GeoBoy
Put HyperVent under the mattress.
Jfet
We use a sleep number air mattress about 8 inches thick. I don't see how moisture could get through the 8 inch air chamber to the bottom but will keep an eye on it.
tony_lee
In one vehicle I fitted a false floor made from screen door security mesh supported up off the base on thin spacers.
In the bigfoot we were told of a bit of a problem by the previous owners. Memory foam mattress of some sort. During the day we just slide a pillow or similar under the end of the mattress and that provides all the ventilation needed to keep it from getting to be a problem.
Tony
Lots of photos with comprehensive captions at MY PICASA Album
Spotwalla map of our travels - Our Travel map
Photomike
pjay9 wrote:
Photomike wrote:
I went with two mattresses, love the loft and no moisture getting through to the base.
So how thick is that? What about sitting up head room?
6 - 8" and with or without the extra mattress on my camper there was not enough room for sitting up.
2017 Ford Transit
EVO Electric bike
Advanced Elements Kayaks
Camper_Jeff___K
Nomad III
Nomad III
I've checked several times under our mattress and never had an issue with moisture forming. We have a cheaper mattress that I think has poor fill in it and springs. Air seems to flow through it easily. We have a 3" memory foam topper on it and that works great for comfort.
What I have thought of doing is fitting and placing a heavy 3/4" grade of cedar fence lattice under the mattress that would provide for ventilation and decent uniform stable support under the mattress.
pjay9
bb...have a memfoam mattress and have had no wet issues, yes there is a brandnew platform with new wood and insulation. My thinking is as before more insulation as you have mentioned. I may put down a 1/2 foil faced board and some bubble and cover the lot with batting and nice fabric. I was just wondering if anyone had any great light to shed. THX for your confirming input!
pjay9
Photomike
2017 Ford Transit
EVO Electric bike
bb_94401
pjay --
I'm assuming that you already have lots of insulation under the finished wood, if not add more that minimizes conductive and radiative heat loss before continuing, then it depends on the type of mattress you have.
I went with a closed cell latex foam mattress, much warmer in winter. No possible vapor migration that causes most of the moisture under the mattress and resultant mold. With a closed cell mattress you can place it on the finished wood and not worry.
If you use your camper in cold weather, where condensation is an issue, and have a conventional mattress or a open cell based foam mattress, use the some what pricey Hypervent matting under the mattress. This is what came under the mattress in my sailboat (available from Defender Marine). It is very effective at dealing with the moisture that is migrating through the mattress from you as you sleep. Mattress stays dry and mold is less likely on the colder camper surface.
'05 Ram 3500, 4x4, DRW, LB, 6spd man, CTD, PRXB exhaust brake, Roadmaster bar
'01 Corsair 10'8" - 4,200 lbs., Xantrex XADC 80A, Link 20, 4-Lifeline GPL-4CT, PowerGate Isolater, 2 AWG wire, PI 30A EMS, 2 Honda EU2000i, parallel kit, ext. duration tank.
pjay9
jimh425 wrote:
I have reflectix now.
So that is what it is called, my foil faced bubble wrap! THX for reminder.
jimh406
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
narcodog
I placed sheets of the foil faced foam under my mattress's, Then I made a tub of, Reflectic. Any way I placed one edge under the foam them attached the upper end to the wall with 3M strips so I could remove it without damaging the wall.
I then put a layer of carpet on top of the foam.
