Well, it rained all day here in the Northwest, and my stuff showed up last week. I decided to start getting it together.
Old speakers were ok, but I wanted a little more punch.
All installed
(only 3 are pictured). When I pulled out the old ones, they were covered in saw dust. I cleaned up the holes with sandpaper and vacuumed real good.
Old receiver. I need to cut the hole about an inch taller. Aslo, my new system is about an inch deeper. I will have to create a frame out of wood to mount the new unit on.
Had to fish wires for new HDMI and TV sound out to the receiver.
Here is the sub being test fit. I got a cover for it so it won't get easily damaged.
And this will be going in tomorrow.
Finally, in order to get to stuff behind the receiver you access it from within the closet behind the paneling. I noticed some moister in there due to a badly sealed TV antenna (prior owner). I'll fix that as soon as it stops raining.
