Jul-30-2020 12:34 PM
Jul-30-2020 05:21 PM
Old-Biscuit wrote:
OK......
If the Cold Inlet/Bypass Valve is the ONLY valve on your WH Tank----NO Valve on Upper HOT Out connection then your LACK of Hot water is due to failed check valve in the HOT Out connection (nipple screwed into WH TANK has an internal check vlve that are common to failure/Clogging etc
Jul-30-2020 04:16 PM
Jul-30-2020 04:10 PM
Jul-30-2020 03:32 PM
Jul-30-2020 02:05 PM
Jul-30-2020 02:02 PM
Jul-30-2020 01:53 PM
Jul-30-2020 01:09 PM
Jul-30-2020 01:05 PM
