tbf1974's avatar
tbf1974
water heater
Hi there. I just purchased a 2014 star craft Ar One 26bh and was wondering how to tell if the water heater has the electric option
  • Pretty easy stuff if you now the make and model… information that is needed to make any repairs or adjustments… and no one can say for sure what you want to know without having the make and model…
    I gave it for Atwood and here it is for Suburban…
    SW6P P= pilot
    SW6PR = pilot with reignitor
    SW6PE= combination pilot and electric
    SW6PER= combination pilot and electric with reignitor
    SW6D=direct spark ignition
    SW6DE=direct spark ignition and electric
  • Thanx for the replies. There is nothing on fuse panel marked water heater so I'm assuming it's just a propane heater
  • Some RV manufacturers do not install interior switches for the water heater. Then, as Old Bicuit said, the two water heater brands have switches right on the water heater itself.
    A very simple way to determine if yours is electric is to look at the circuit breakers and see if there is one marked Water Heater.
  • For Atwood
    Pilot Relight P IN MODEL # -
    Heat Exchange H IN MODEL #
    Electronic Ignition E IN MODEL # -
    Combination Gas/Electric C IN MODEL # -
    GC10A-3E
    G= gas – C=combination gas/electric – 10= gallon – A= screw in heat element – 3= revision number – E= electronic ignition
    (or DSI = Direct Spark Ignition.)
    What make and model do you have???
  • If it's a Suburban Brand...
    In outside compartment there will be an ON/OFF switch in corner and there will be 2 reset buttons on rubber cover.
    The electric element will be under a cover behind gas valve
    If it's an Atwood Brand....
    Control panel will have 2 switches
    Electric element will be on backside (inside RV) under a cover
    Doesn't the data sheet in cabinet/drawer list the various appliances etc.?
  • If your trailer has a 'systems control panel' and the water heater is gas and electric, there will be two switches for the water heater. One is for the ignition for gas operation, the other to turn on the 110v heating element for electric operation.
  • Typically, you will have a switch with your master switches that says electric. That is where mine is on my Laredo. You will also have an on/off switch inside the outside cover of the water heater. This switch has to be on before you turn on the inside switch.
