modrodr
Apr 10, 2019Explorer
Water Heater
Hi guys! First post. I recently purchased a TT for quick weekend getaways with the family. We took our first trip this past weekend and all went well. We did have one issue, and that issue was lack of hot water. I hooked up to my water supply and turned the hot water on inside to work the air out. Once the air was out, I flipped the water heater switch inside and waited an hour. I never had hot water. During our set up I noticed that the plugs weren't working so I reset the GFI in the RR and all was good. As I was packing up the next day I realized there are (2) resets for the water heater on the outside of the trailer. I had already unhooked from power and water so I didn't hit the reset to see if that would make a difference. Your thoughts? Also I never turned my propane on, but it is my understanding the water heater can run off of shore power without the need of propane, is that correct? Again, sorry for the rookie questions, just thought you may be able to shed some light based on past experience etc.
Thanks in advance!!!
