So, I hooked up the hose from the house to the camper, and turned it on. I went back up to the camper to discover water pouring out the back of the truck from under the camper. I immediately shut o...
If you were connected without the pressure regulator then the weakest connection in the TC went first. It may only be one connection since some pressure was relieved went it broke loose. Seems to me I remember seeing something about the water lines in an RV are manufactured to withstand up to 70-80 lbs.
