โJul-10-2013 11:19 PM
โJul-14-2013 08:23 PM
โJul-14-2013 07:09 PM
โJul-12-2013 01:37 PM
โJul-12-2013 01:11 PM
TomG2 wrote:
I was not trying to be argumentative either, just letting the OP that there are different opinions out here. FYI: Recent GM 2500/3500 pickups are rated at either 1,500 or 2,000 pounds tongue weight with or without weight distributing hitches. The short beds get the lower rating.
โJul-12-2013 12:42 PM
โJul-12-2013 12:29 PM
TomG2 wrote:
What excess wear would towing a trailer with 500 pounds of tongue weight cause on a tow vehicle designed for 1,000 pounds of tongue weight?
More comfortable? Not unless something is wrong or out of balance.
Safer? The manufacturers know what is safe and state their requirements clearly. Hitches are not the way to cure an ill handling unbalanced trailer.
Cost? Not a factor at all. If you need one, you need one. If you think that any hitch is going to turn an underpowered undersprung tow vehicle into a super towing machine, you will be disappointed.
Read some of the many weight distributing threads on here and you will discover that no hitch is perfect and none will cure all towing problems.
โJul-12-2013 11:09 AM
โJul-12-2013 10:42 AM
โJul-12-2013 04:59 AM
โJul-11-2013 09:36 PM
โJul-11-2013 03:57 PM
โJul-11-2013 03:42 PM
Steve 911 wrote:What is the tongue weight and what are you towing with?
---Is a WDH and anti sway devise start to be considered for safety?
โJul-11-2013 06:20 AM
โJul-11-2013 06:11 AM
