โJan-13-2016 04:24 PM
โJan-15-2016 08:41 AM
jimh425 wrote:mkirsch wrote:
The dead weight of the tongue pries down on the shank/extension. The WD bars pry up.
I think we just have a terminology problem. My point is the weight doesn't disappear or is attached differently just because you hookup a WDH. The WDW is designed to push up not down on the hitch, but to do that the force still goes through the hitch. There are no other attachment points to the truck. If you are worried about hitch strength, a WDH isn't going to fix it. The lever arm is still 4 feet.
โJan-15-2016 07:41 AM
mkirsch wrote:
Kayteg1,
We're not just talking about hitching a trailer to the receiver on a truck here. There's a 4' extension between the truck and the trailer, and even a light trailer is going to put a lot of force on the truck's receiver with all that leverage. The WD hitch will negate some or all of that, and is really a "necessary evil" in this situation.
Alternatively I guess he could go and get an F550 with a 12' flat bed and the back axle installed right at the extreme rear of the frame. That'd be ideal, mostly. Might have to watch that he doesn't overload the front axle because the camper will be 50/50 on the front and rear axles. Plus the darn thing will take two football fields to turn around. Forget using it as a daily driver or going anywhere "normal" like you would with a typical pickup truck.
โJan-15-2016 07:17 AM
Kayteg1 wrote:
The 3-axle trailer had pintle hitch, so WD was not possible even if I wanted it.
โJan-15-2016 07:06 AM
โJan-15-2016 04:02 AM
I don't think it's normal to add a WDH to tow behind a 4' extension to tow light weights. I'm not saying you can't, but I don't think it is at all normal. In any case, WDH won't impact the leverage added to the truck at the hitch since it is ball mount back.
โJan-14-2016 10:28 AM
โJan-14-2016 10:14 AM
โJan-14-2016 05:58 AM
โJan-14-2016 05:07 AM
mkirsch wrote:
WD hitches have distinct advantages when you're traveling hundreds of miles at highway speeds.
โJan-14-2016 04:56 AM
ticki2 wrote:Kayteg1 wrote:
I did tow quite a bit in my life, including few thousands miles with 18,000lb equipment hauler and NEVER used WD bars.
Would you mind telling us what vehicle and trailer hitch you were conventional towing 18000 # without a WD hitch .
โJan-14-2016 04:00 AM
mkirsch wrote:
Not everyone is trying to tow a 9000lb trailer with a half ton truck or midsize SUV.
My Reese Titan receiver is rated to 18,000lbs conventional towing without a WD hitch.
Construction equipment on flatbed trailers are almost always towed without WD behind pickup trucks.
That's not to say just because they can/do means everyone else should too. If you're going across town to a job site at 35MPH, that's one thing. WD hitches have distinct advantages when you're traveling hundreds of miles at highway speeds.
โJan-14-2016 03:52 AM
crossent wrote:
My dually has upper stable loads and rancho 9000's. I think I will take the timbrens off my 95 and slide them under the dually. The dually handles my single axle boat just fine. The toy hauler is a tandem axle . Just thought WD to bump up my hitch capacity. Not trying to raise the back of the truck.
โJan-14-2016 03:43 AM
โJan-14-2016 03:01 AM
โJan-13-2016 09:18 PM
