cs2kplus's avatar
cs2kplus
Weight Distribution Hitch Value
Hi. Looking at a 2004 1500 Chevy Tahoe to pull a 6500 lb rv. Weight capacity for its gear ratio is 7500 lbs max. However, on the hitch it says 12,000 lbs weight distributing. Now...I was told that using a weight distributing hitch will increase your tow capacity. Seems to be the case here. Is this correct?
