JBarca
Oct 22, 2023Nomad II
Huntindog wrote:
john, I am pretty sure that he is talking about the EQUALIZER brand components wich is not a standard WD hitch. Your Reese is a standard WD hitch.
Hi Huntingdog,
Yes, true maybe. I was commenting only about the shank; the Reese shank goes from 2 1/2" down to 2" at the hitchhead. It can be an option as long as the width and hitch head hole spacing work out.
But, if his hitch head uses a washer stack and pin setup for the hitch head tilt, the Reese cast steel shank will not work. The head tilt adjusting pin will fall into the cast slot in the center of the 2" wide portion.
Thanks
John
44,026 PostsLatest Activity: Feb 24, 2025
